Hi there! I'm still alive here! :D It's happening after some minutes. Just after equip an item on webserver.
Tested version 4.5.4 and happened the same..
root@localhost:/opt/mudfish/4.5.4/bin# ./mudrun -a 0.0.0.0
Segmentation fault
Ps: I cannot find whats my ip on item -> equip -> Site
Please give it a try to other version with https://mudfish.net/releases/mudfish-4.6.1-linux-armv7l.sh
Hi there! Looks like ok but i think my ip doenst change it all
Current
2804:14c:6583:41b7:8c90:77ff:fe36:1f26
After
Somehow give me this message on mudfish's web:
Error
Mon, 15 Jul 2019 13:24:24 GMT [2.864687] [CRIT] Assert ((odr_defaultGatewayStr) != 0) failed at ODR_AddSNodeToRoutingTable (./mud/os/linux/syscalls.c:1940) with 0
Oh my god...... :-( You're under IPv6 only network? If then you're first IPv6 customer. But definitely mudfish will be failed because it's not supporting IPv6 yet. If you can use IPv4 network to the public area, please try to use it.
Ok! I think it`s an Ubuntu network configuration. My public ip is not ipv6
Hi there!
Ipv6 disabled on Ubuntu and now my public ip is ok.
# wget -qO- http://icanhazip.com
189.xx.118.xxx
I've confirmed that mudfish is not working here
This appears again on webconsole
Error
Wed, 17 Jul 2019 13:12:37 GMT [2.636411] [CRIT] Assert ((odr_defaultGatewayStr) != 0) failed at ODR_AddSNodeToRoutingTable (./mud/os/linux/syscalls.c:1940) with 0
I've installed lynx and test on https://myip.mudfish.net and my ip doesnt change for sure.
# lynx https://myip.mudfish.net
189.xx.118.xxx
You're accessing directly without Mudfish.
Mudfish isn't working.
Did you set Full VPN mode or equipped 'What's My IP?' item? Without
explicit setting, Mudfish doesn't change your public IP at all. Please
see the following document to check whether it's set correctly.
* Check your public IP
Take a look on second screenshot. Looks like Process is not ok.
Could you please show me full messages of "Core Logs" which found at "Status -> Process" menu?
Sure! Here we go!
This appears again after log in.
Mon, 22 Jul 2019 13:38:24 GMT [2.701301] [CRIT] Assert ((odr_defaultGatewayStr) != 0) failed at ODR_AddSNodeToRoutingTable (./mud/os/linux/syscalls.c:1940) with 0
:-( No idea why this issue happens without checking more details. Could you please show the result of "netstat -nr" command? Sorry for bothering again.
Hi!
Here you go! It's the same route table before and after run mudfish..
Okay.. As you can see the result of `netstat -nr`, the default gateway isn't existing on your routing table. I'm not sure why you didn't set it but please try to set and test again.
Hi there! I've add a new route default
# route add default gw 192.168.50.1 eth0
# netstat -nr
Kernel IP routing table
Destination Gateway Genmask Flags MSS Window irtt Iface
0.0.0.0 192.168.50.1 0.0.0.0 UG 0 0 0 eth0
192.168.50.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
And run mudfish again but it's not ok yet
189.xx.118.xxx
Did you set Full VPN mode or equipped 'What's My IP?' item? Without explicit setting, Mudfish doesn't change your public IP at all. Please see the following
Terms Of Service | Privacy Policy | Contact Us | We're hiring!
CEO: Mijung Han , Phone: +82-2-2659-0823, Fax: +82-2-2659-0824, Business License: 105-20-21666
Address: 8F #803, 165, Magokjungang-ro, Gangseo-gu, Seoul, 07788, South Korea
2011-2019 Mudfish Networks
Are you meaning that even after adding the default gateway you still see the same error message? Please attach your core logs if possible because without it it's hard to follow the reason.
Hi there! Here you go!
https://docs.google.com/document/d/1IcIye-h4mVhe51M5yWIRMBqWaVGL89QrDR1bi9Qcl4o/edit?usp=sharing
Okay. When I checked your hours, it seems it becomes better than before. :-) However I need to check little bit more to see whole system. I'm curious that sending Problem Report works fine now. If then please try to send the problem report at that moment after mudfish is executed properly but it seems it doesn't work.
When I checked your log, it seems no fatal issues so I assume the basic functionality works but I need to double check that the routing table is set properly.
Problem reported successfully on Support -> Problem Report
https://mudfish.net/forums/7/topics/56358
Thanks a lot
Okay. I'll leave my answer at the problem report topic.
5 year ago
