Can u guys add india or singapore server in PUBG MOBILE PLEASE ?! that would bring a huge amount of population to mudfish !
Mudfish Mobile App is in available.
Please pick a node that good to use.
But i want to use the Equip Item not the Data Plan.. :L And there is only one Option of Aisa(japan) server.. would it be ok or the same item(equip item Game)FAst connect mode to use it to india or singapore server?or you guys gonna add it ?
Unfortunately it's not officially supported by Mudfish yet. As workaround you should use one of methods at Unsupported Games. And if you want to see it officially at Mudfish, please send me some game packets using Packet Capture with Mudfish link while playing the game with Full VPN mode.
Would Wireshark packet capture work ? i m pretty newbie in this but where to send the files and in what extension it should be in ?
I believe Packet Capture with Mudfish is easier than Wireshark
but i dont have any full vpn mode on ? it would cost me 1 month bro if i equip item :L or u can refund or revert after its done ? and also list where to send the packet..
Equiped item and when doing packet dump file uploading it keeps getting Internal Error ? file size is around 3 to 5 Mb only :L
i somehow managed to upload 1 file which of small size.. check it if u can , if it gives enough info to you :) thank you however when try to upload a bigger file i keep getting interal error when uploading the packetdump
Mudfish is not even working for the Official PUBG MOBILE ASIA (Japan server) lol.. i am also talking about via emulator not mobile :L Even the official server it says unable to connect waiting for client thing Cannot connect to DCHP client :L Any solution I just want PUBG mobile(Global version) Vpn for Asia Server its upto you now :L also just refund or revert the thing i bought :L
You can try to install Mudfish VPN Launcher on your Operating System then enable Full VPN mode then run the app in the emulator
2 month ago
