As you might guess, the physical server is at South Korea. Do you want to have one in South Korea instead of Philippines?
do it make difference on gaming? I am playing cabal Philippines and I want to recommend your VPN to other players.
You should consider if the game has policies to region restriction. The Somagu server located in Korea so your public IP will appeared as Korean if you configure Virtual Private Network in it.
yes there is a region restriction on cabal Philippines. and about the ping while on game. can we improve it? I can pay extra if I get better performance while playing. and I will recommend this for all players overseas.
How to pick the best mudfish node for game I play?
5 year ago
