teru
10 year ago
Technical Support
Hi, I've got small problem with Blade & Souls (EU).
When using FastConnect mode, after a short time few in-game features become unavailable: Currency Exchange, Daily Dash, Hongmoon Store and changing currently logged in character. The first 3 do not even attempt to work, no error, no blank window popping up. Changing character results in loading screen stuck at 0%.
There's no such problem when turning off FastConnect mode, but quality of connection noticeably suffers with random spikes of delay and stutters (over both TCP and UDP).
Using FastConnect through UDP it's silky smooth, responsive and stable, everything you would ever want from connection to a game. It beats WTFast, Pingzapper and any other similar service I've tried in the past.
In process log I get:
[18.723071] [INFO] **MUDEC_00176**: tcprelay: Failed to find SID for destination 78.11.252.19.
[18.723071] [INFO] **MUDEC_00038**: TCP relay from the client (10.254.227.193:55966) to the backend ((null):(null)) failed.
and
[332.897041] [INFO] **MUDEC_00178**: udprelay: Failed to find SID for destination 91.108.68.186.
[332.897041] [INFO] **MUDEC_00181**: udp_relay: Failed to find the backend for 91.108.68.186
The latter two repeatedly with different IP addresses.
It's not major inconvenience, for that high quality connection I can relaunch the game every time I need access to any of those features, but figured there's nothing wrong with striving for perfection.
Is there anything I can do on my end to fix the issue?
