Mudfish Forum
Technical Support
9 year ago
Whenever I exit game, and then start a new one playing PUBG... I always
need to exit Mudfish just so I can browse and play again and then start
again, creating a new network and all. Is there a way where I can just
continue on without having to do all these?
I also cannot browse while Mudfish is on. :(
My friends, who use my aliases, don't have these problems I am encountering. I usually stream to Twitch/Facebook... I am glad that my ping is better but then I can't access anything if I'm not on Full VPN Mode so therefore I cannot stream too. What I'm trying to say is why does it work to them without any problems but me I have to go Full VPN Mode just to browse/stream. I tried different things already, like FastConnect, stopping my AntiVirus, updating NIC... I still can't get it to work without me having to reconnect every now and again just to make my internet back up. Also, after a while even the localhost address of mudfish is not accessible.
loxch
(Forums Admin)
9 year ago> Whenever I exit game, and then start a new one playing PUBG... Interesting... Are you meaning you can only browse the internet while Mudfish is running with Full VPN mode enabled? It doesn't work properly with just equipping the game item, right? If you're familiar with Command Prompt, please try to do: * Turn off Full VPN mode and restart the mudfish. * Launch the command prompt and ping 8.8.4.4 IP. Is it working properly? Sometimes DNS could cause this issue but at this moment I don't know why.
Monyo
9 year agoYes, you're right, I can't browse and it doesn't work properly with just equipping the game item. So I tried what you said, it's pinging 8.8.4.4 properly and I can browse for the first minute after running Mudfish, after that, I can't but I still can ping 8.8.4.4 I always alt tab while in game and browse while it's dead game and I can't do that. I also stream which I also cannot do. If this info should help: Win10 64bit updated, i7 4790K, GTX 1070, Maximus Hero VII Motherboard, 16gb DDR3 RAM. One more question, I think your Discord site item is only working on its website, not the application. How can we make it work on the app?
loxch
(Forums Admin)
9 year ago> So I tried what you said, it's pinging 8.8.4.4 properly and I can browse for the first minute after running Mudfish, after that, I can't but I still can ping 8.8.4.4 Are you using Mudfish under network firewall? If you can still ping to 8.8.4.4, it means your internet to outside is still working. It looks like DNS resolving doesn't work properly. Which DNS server are you using? > One more question, I think your Discord site item is only working on its website, not the application. How can we make it work on the app? Umm.. Is this application (app) for PC (desktop)? Or smartphone?
Monyo
9 year agoDesktop, of course. I use DHCP settings... Should I change my IPv4 settings and use 8.8.8.8 and 8.8.4.4? My firewall is off, already tried without AV, without Firewall, still same.
Monyo
9 year agoSo, I tried to do that... It's fixed now. Turned on my Discord item and it's also fixed now. Thanks but you gotta reply faster, man :)
Monyo
9 year agoYesterday everything worked fine but today I still get my old ping on Discord and that means Mudfish isn't connected on my Discord, right?
loxch
(Forums Admin)
9 year agoWhich Discord server are you accessing? If I can know the full name of server, it'd be more helpful.
Monyo
9 year agoI think it was Singapore11.
loxch
(Forums Admin)
9 year agoOkay.. I'd updated the discord item now. Could you please test it again?
Monyo
9 year agosingapore495 is bad as well.
loxch
(Forums Admin)
9 year agoI'd updated it again for singapore495.discord.gg server. Could you please test it again?
9 year ago
