MUDFISH
  • Home
  • Product
    • Main Products
    • Mudfish Cloud VPN
    • Mudfish Mobile App
    • Mudfish Browser Extension
    • Other Products
    • Mudfish DNS Client
    • Mudfish Adclean
    • Mudcat - Port Sharing service
    • Muddog - Free VPN
    • Somagu Homepage
  • Download
  • Shopping
  • Forum
    • Home
    • List
    • Announcement Technical Support
  • Document
  • Miscellaneous
    • Document
    • Wiki
    • Status
    • Nodes Status
    • Tools
    • What's My IP?
    • Image Uploader
    • DNS Client
    • Ping Test
    • Text Bin
  • Dark Mode
  • Sign In
nyconing
8 year ago
Technical Support
no free trial?
  • URL Copy
  • Show this topic only
  • loxch (Forums Admin)
    8 year ago
    When I checked your account, it seems you already bought a mudfish  credit. :-) Please let me know if there's any problem while using mudfish.
  • nyconing
    8 year ago
    Im playing Blade and Soul Taiwan.I facing random disconnection WHEN CHANGING CHARACTER or going inter-server dungeon platform. I have noticed the problem will persist only when the 2nd node is routed.
    8 year ago
    So are you meaning that using 1 mudfish node (basic mode) it works properly?  And did you check Blade and Soul link too?
  • nyconing
    8 year ago
    I resolved by trying other nodes on 1st node in advanced mode. But facing another problem which is website not directed properly, suspect DNS problem.
    8 year ago
    It seems the problem is little bit complicated.  Could you please confirm that it's also same with Full VPN mode enabled?
  • nyconing
    8 year ago
    I cant login into website when advanced VPN connected (HK HostUS - TW Google). The website is 'https://tw.ncsoft.com/login/sso?authn_token=?????' You can download NCLauncher from tw.ncsoft.com and login and wait for first-page or click 活動情報 if you want reproduce problem.
    LOG IN : NCSOFT
    Something went wrong on our end.Please try again in a few minutes. O
  • nyconing
    8 year ago
    FullVPN is fine since it is only basic mode supported. I tried to add missing route 203.67.202.129 pointing to mudfish gateway but no luck too.
    8 year ago
    I'm still confused at this moment.  You said Full VPN mode is fine to access the website, right?  Then did you try to set the same mudfish node for mudfish game item and turn off Full VPN mode?  Was it same? If it doesn't work properly with game item, it seems it requires for the item to be updated.
  • nyconing
    8 year ago
    Full VPN mode is fine to access the website (yes). did you try to set the same mudfish node for mudfish game item and turn off Full VPN mode?  Was it same? (full VPN mode does not support advance mode, thus, working fine when basic mode)
    8 year ago
    Umm... So are you meaning that just with the basic mode for game item without Full VPN mode enabled it works fine too?
  • nyconing
    8 year ago
    yes.
    8 year ago
    Oh... It seems your issue is that only with the advanced node mode it doesn't work properly, right?   Then which mudfish nodes did you pick for the advanced node mode?
  • nyconing
    8 year ago
    2nodes problem found in advanced mode by following:Taiwan HostingInside( Random disconnect when char-login) Taiwan Google (Cant login into game website correctly)
    8 year ago
    Okay I'll test your problem on my side too.  Thank you for your feedback.
  • nyconing
    8 year ago
    Hi, heres has new update for this issue. Its working fine when using FastConnect mode.
MUDFISH
MUDFISH
Terms Of Service Privacy Policy Refund Policy Language
Mudfish Networks
Contact Us We're hiring!
Miscellaneous
Mudfish AdClean Mudcat - Port Sharing service Muddog - Free VPN Somagu Homepage
© 2011-2025 Mudfish Networks Inc.
