Mudfish Forum
Technical Support
Corumon
9 year ago
Technical Support
Hi, I just started trying out Mudfish but when I am using Wifi, mudfish seems to be not working. However, when I use an ethernet cable with Mudfish it works.  Is it because my settings aren't properly configured or some kind of port forwarding issue with Wifi?On adapter's setting I found TAP-Win32 Adapter V9 named as Ethernet 2. Is that something to do with this issue? Seems like my wifi is not compatible with Mudfish and not sure why.
