Greetings, I am looking for some technical help/advice for running mudfish on my router. I already read some of the instruction over at the router installation, my understanding is only ar71xx architecture is supported at the moment.
Unfortunately I bought a gl-inet with different architecture (because it is the cheapest, frankly, ramips arch).
My router details
https://www.gl-inet.com/products/gl-mt300n-v2/
https://openwrt.org/toh/gl-inet/gl.inet_gl-mt300n_v2
So, being a noob at openwrt,
My question is,
- Is it possible to compile chaos calmer my self to run mudfish just by doing the instruction over at https://github.com/openwrt/chaos_calmer
- Or is it possible to force mudfish package to force install on ramips? (I wont hope it runs smoothly, worth trying tho?)
Thankyou.
8 year ago
