h27771420
8 year ago
Technical Support
Hi,i have some question about Lost Ark crash.Every time i run the game, it always crash after "Xigncode" appeared. It just like the image. I goole this error code. It tell me two problems.    1.Disk Memory doesn't enough. (My disk memory is enough.)   2.It cant pass over Firewall. (I tring put everything that relate lost ark and Mudfish and Xigncode in exception List , but still not work.) Q_Q I try lot of method ,but it never work. Q_Q At the last ,i try to use FULL VPN . It surprisingly work! Even though i finally find this method, but i still not give up. Because i don't want use FULL VPN all the time, the Net speed is too bad. Can you tell me any solution to let it work? (other than Full VPN) Thank you. PS.I just have windows Firewall, don't have anyother.
