Mudfish Forum
Technical Support
cabal philippines. i can launch and update the cabal. but when logging in to my account cannot. same problem last time. please help. yesterday dont have problem. thanks. i already tried full vpn but still the same
Mudfish Forum
Please confirm that How to check the basic functionality works fine in your environment. It's a first thing you should test.
We have two PH nodes; PH Asia (Philippines - CloudSigma 2) and PH Asia (Philippines - CloudSigma). Please check the basic functionality test against to these nodes.
i already try all.changed tcp udp. full vpn . maybe u can change the IP. last time i faced same problem then u just change the IP and it works again. thank you. Maybe u can change again the ip. Please. Thank yo u so much
please help us to change the IP so we can play cabal ph. please thank you. i think 3 to 5days already down cannot play
It works now
7 year ago
