index123
10 year ago
Technical Support
Stop MUDFISH Core process.
오류: 프로세스 "mudfish.exe"을(를) 찾을 수 없습니다.
Stop MUDFISH Flow Controller process.
오류: 프로세스 "mudflow.exe"을(를) 찾을 수 없습니다.
Stop MUDFISH Launcher process.
오류: 프로세스 "mudrun.exe"을(를) 찾을 수 없습니다.
Stop Mudfish first
Output folder: C:\Program Files (x86)\Mudfish Cloud VPN
Extract: mudadm.exe... 100%
Extract: muddiag.exe... 100%
Extract: mudfish.exe... 100%
Extract: mudflow.exe... 100%
Extract: mudrun.exe... 100%
Extract: mudrun.ico... 100%
Extract: mudrun_new.ico... 100%
Extract: dbghelp.dll... 100%
Created uninstaller: C:\Program Files (x86)\Mudfish Cloud VPN\uninstall.exe
Extract: devcon.exe... 100%
Extract: tap0901.sys... 100%
Extract: tap0901.cat... 100%
Extract: OemWin2k.inf... 100%
devcon.exe hwids returned: 0
Update miniport adapter
Updating drivers for tap0901 from C:\Program Files (x86)\Mudfish Cloud VPN\OemWin2k.inf.
Drivers installed successfully.
devcon update returned: 0
devcon cumulative status: 0
Create folder: C:\Users\Park\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Mudfish Cloud VPN
Create shortcut: C:\Users\Park\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Mudfish Cloud VPN\Mudfish Launcher.lnk
Create shortcut: C:\Users\Park\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Mudfish Cloud VPN\Uninstall Mudfish.lnk
Completed
설치시 이런 오류의 명령어가 뜨는데 어떻게 해야 설치가되죠?
예전엔 됬는데 지금은 안되서 재설치하려는데 저렇게됩니다
