Mudfish Forum
Technical Support
hatimu4445
4 month ago
Technical Support
Hello Mudfish Support,
I'm experiencing an issue where my public IP no longer changes when connecting through Public Nodes.
Setup:
- Game: Cabal Online
- Node Mode: Full VPN based
- Selected Public Node: HK Asia (Hong Kong - So-net) - 1244
- Username: hatimu4445
Problem:
When I connect, the "Current Public IP" still shows my real ISP IP (157.10.1.37) instead of the selected public node's IP. This happens with every public node I try (Hong Kong, Sydney, Europe, etc.) — none of them change my IP anymore.
This used to work perfectly before: as soon as the VPN connected, my IP would immediately switch to the location I selected. The behavior only changed recently.
Could you please check:
1. Whether these public nodes are still active/online
2. If there's a config or routing issue on my account
3. Whether Full VPN mode is correctly redirecting all traffic
My account uses Pay Per Traffic and I still have traffic balance remaining (43.33 GiB). Please let me know what additional logs or info you need.
Thank you.
