Mudfish Forum
Problem Report
6 year ago
FFXIV Packets (Item not working)
Mudfish does not reduce my ping in ffxiv unless full vpn mode is on
Weird.. Are you meaning that with Full VPN mode it works fine? Without Full VPN mode enabled, please check How do I know if its working? section and check the realtime traffic graph whether it moves like that.
I'm curious that the realtime traffic graph is actively moving while playing the game.
chumpus
6 year agoI checked and the graph isn't really moving. Only a tiny bit but nowhere near the numbers it should be
weongyo (Forums Admin)
6 year agoWeird... When I checked this packet dump properly, the game server IP 204.2.229.114 should be covered by current mudfish game item. :-(
When you get a chance, please send us another packet dump.
chumpus
6 year agohttps://mudfish.net/forums/7/topics/69109
Here is the second packet dump, sorry to keep you waiting
chumpus
6 year agoI just tested the game with full vpn mode, no vpn, and a different vpn and I realzised that I was mistaken with something. Not even full vpn mode really reduces ping. It works for my web browser and everything else which made me think it had to be working with my game, but with final fantasy it's very inconsistent and usually not doing much when compared to having no vpn and using a different vpn. I'm sorry for the confusion I just wasn't sure what was happening
6 year agoOkay. I hope your problem is now solved. :-) Please let me know if there's still an issue.
chumpus
6 year agoOh no the issue didn't go away, I just realized that it wasn't working in the game at all
I have no idea what's going on
6 year agoPlease confirm that How to check the basic functionality works fine in your environment. It's a first thing you should test.
chumpus
6 year agoI checked and according to the process log it's not working at all. From my understanding it was unable to connect to any of the listed ips and shut itself off (I'm not sure though). Here's the log
[STDOUT]
[0.001996] [INFO] mudfish v5.3.2 (for x86_64)
[0.002993] [INFO] Timestamp: Thu Feb 18 18:36:36 2021
[0.002993] [INFO] Connection protocol: udp
[0.003990] [INFO] Authenticating...
[0.595887] [INFO] Fetching the static nodes...
[2.684739] [INFO] Fetched 508 static nodes from the master.
[2.689768] [INFO] TAP-Win32 Driver GUID {89DF31F8-8FC2-4EBC-99EC-BA16E2FD87A6}
[2.689768] [INFO] TAP-Win32 Driver Version 9.9
[2.689768] [INFO] TAP-Win32 Driver MTU 1500
[2.689768] [INFO] Setting TAP-Win32 Adapter v9's MTU to 1400
Ok.
[2.810539] [INFO] TAP-Win32 Driver TcpNoDelay diabled
[2.810539] [INFO] TAP-Win32 Driver TcpAckFrequency 1
[2.810539] [INFO] TAP-Win32 Driver TCPNoDelay 1
[2.826497] [INFO] Uses the macaddr for msk(4) (cached).
[2.833478] [INFO] Ready
[2.837468] [INFO] [2.837468] [INFO] tcp_relay: listening on 0.0.0.0:1 (fd 0)
udp_relay: listening on 0.0.0.0:1 (fd 0)
[2.840460] [INFO] Waiting until the client's ready to handle the routing path list.
[2.933926] [INFO] Listening the management console at 127.0.0.1:59352
[4.747689] [INFO] DHCP request for 00:ff:89:df:31:f8 (LAPTOP-7F1NKVF4) from interface
[4.755630] [INFO] DHCP discover for 00:ff:89:df:31:f8 (LAPTOP-7F1NKVF4) from interface
[4.757625] [INFO] DHCP request for 00:ff:89:df:31:f8 (LAPTOP-7F1NKVF4) from interface
[4.757625] [INFO] DHCP Client got IPv4 address now
[5.316640] [INFO] tcprelay: Failed to find SID for destination 192.168.1.1.
[5.316640] [INFO] TCP relay from the client (10.254.110.192:65498) to the backend ((null):(null)) failed.
[5.843287] [INFO] MFP 0 RouteAdd - 109.244.0.0 255.255.0.0 493 102 0 n -1
[5.843287] [INFO] Fetching new static node SID 493...
[6.704696] [INFO] re357: Associating with ip 45.77.63.124 port 10008
[6.704696] [INFO] re357: Connected to 45.77.63.124:10008 (UDP)
[6.705692] [INFO] MFP 0 RouteAdd - 114.31.32.0 255.255.224.0 493 102 0 n -1
[6.705692] [INFO] MFP 0 RouteAdd - 116.211.0.0 255.255.192.0 493 102 0 n -1
[6.706689] [INFO] MFP 0 RouteAdd - 121.78.0.0 255.255.0.0 493 102 0 n -1
[6.706689] [INFO] MFP 0 RouteAdd - 121.79.0.0 255.255.0.0 493 102 0 n -1
[6.706689] [INFO] MFP 0 RouteAdd - 124.150.152.0 255.255.248.0 493 102 0 n -1
[6.707687] [INFO] MFP 0 RouteAdd - 172.107.98.0 255.255.254.0 493 102 0 n -1
[6.707687] [INFO] MFP 0 RouteAdd - 180.182.57.0 255.255.255.0 493 102 0 n -1
[6.707687] [INFO] MFP 0 RouteAdd - 183.110.0.0 255.255.248.0 493 102 0 n -1
[6.708684] [INFO] MFP 0 RouteAdd - 183.111.189.0 255.255.255.0 493 102 0 n -1
[6.708684] [INFO] MFP 0 RouteAdd - 183.111.190.0 255.255.255.0 493 102 0 n -1
[6.708684] [INFO] MFP 0 RouteAdd - 183.111.191.0 255.255.255.0 493 102 0 n -1
[6.709681] [INFO] MFP 0 RouteAdd - 195.82.50.0 255.255.255.0 493 102 0 n -1
[6.709681] [INFO] MFP 0 RouteAdd - 199.91.189.0 255.255.255.0 493 102 0 n -1
[6.710678] [INFO] MFP 0 RouteAdd - 204.0.0.0 255.252.0.0 493 102 0 n -1
[8.462377] [INFO] MFP 0 RouteAdd - 211.39.128.0 255.255.255.0 493 102 0 n -1
[8.462377] [INFO] MFP 0 RouteAdd - 222.122.222.0 255.255.255.0 493 102 0 n -1
[8.462377] [INFO] MFP 0 RouteAdd - 220.95.221.0 255.255.255.0 493 102 0 n -1
[8.463377] [
chumpus
6 year agoHi! I'm actually sending this because I finally got the app to work! Thank you for your patience and I hope you have a good one!
6 year agoCool! :-) I hope now everything goes well with mudfish. Please let me know if there are any other problems.
6 year ago
