Mudfish Forum
Problem Report
32 days ago
this is the packet dump for Mistfall EU servers, can you please add it ?
weongyo (Forums Admin)
32 days ago:-) Thank you for sending the packet dump. Based on your packet dump, I had updated the game item by adding "Europe (Frankfurt)" destination. Could you please test with it? If it is not working properly, please let me know.
auda
32 days agoHello,
wow thanks for the quick reply ^^ really appreciated
to be honest i dont know whether it works or not, as i still has the same ping
do you have any recommendation for certain configurations to lower the ping?
32 days agoYou're welcome! The dump confirms that the Frankfurt traffic is covered by the updated item. Turn off Full VPN, open Mistfall Hunter → Setup → Nodes, use Basic mode, click the magnifier, and test the lowest-score routes. For similar scores, choose the flattest RTT graph/lowest RTT stddev, and restart the game after each change. If Basic mode does not help, try the recommended Advanced-mode routes. Ping may remain unchanged when your ISP's direct route is already near-optimal.
However if you still feel that the ping isn't changing, please send us another packet dump if possible.
32 days ago
