Mudfish Forum
Problem Report
6 year ago
New World US East Server
MMO New World
Alpha test server
US East (amazon aws host servers)
Let me know if you need more information.
Steps for packet dump:
Launch client, select world, run around do actions, chat, log off.
:-) Thank you for sending the packet dump. Based on your packet dump, I had created an item; New World. Could you please equip and test with it? If it is not working properly, please let me know.
cattboy
6 year agoThank you for making new Item.
Tested many different Node (and New FastConnect Mode w/ different node). Ping using Mudfish is not lower than without using Mudfish
I try all nodes in Basic.
Advanced nodes (A few combinations, using node close to AWS Server in Virginia)
and Multi Path.
Basic mode with lowest score provides same ping as without mudfish. I will try to use it when I play to see if gameplay "feels" better :)
Any tip for me to lower more is helpful.
Australia -> US East is long route, I understand limitations but everything helps :)
~cb
weongyo (Forums Admin)
6 year agoDid you try to turn on "Include the result for the advanced mode" option which found under 'Setup -> Nodes' menu? When it's enabled, Today's Pathes will show you the advanced results for route pathes.
However what's current ping without mudfish?
cattboy
6 year agoThank you Weongyo.
My ping without MF is 245ms
My ping with MF is 245ms
My node routing Realtime RTT inside MF GUI is 216ms with Basic Mode -> Selecting Amazon EC2 / Lightsail (best RTT options)
My node routing Realtime RTT inside MF GUI is 230ms with Advanced Mode -> Auto Selection
"Include the result for the advanced mode" -> I've enabled this.
Also here:
I changed to the suggested Todays Path
in game: 254
Now I try
Now I turn off mudifsh
FYI.
This doc doesn't tell me how to FIND Today's Pathes, but I found it :) https://docs.mudfish.net/en/docs/mudfish-launcher/setup/
Thank you for your help.
When more servers open up, I will help you with providing IP address packet dump so more customer can use :)
6 year agoWeird... Could you please confirm that it's also same with Full VPN mode enabled? If it makes any ping difference, please send us another packet dump based on Packet Capture with Mudfish document.
cattboy
6 year ago:)
I do my tests off-hours to avoid peak traffic. Currently 6:00am AEST on Saturday when starting my testing.
No Mudfish Activated
Full VPN Mode
Mudfish activated Ping
My ping dipped to 236. which is hte lowest I've ever seen it.
I cannot add the .pcap. to this chain so I've emailed it to you
To: support@loxch.com
Subject: Attn: weongyo (Forums Admin) - forums/7/topics/71375
Thank you!
6 year ago:-) Thank you for sending another packet dump. I'd updated the game item again so when you get a chance, please test it again.
cattboy
6 year agoThank you!
6:47am Mon AEST
Todays Route suggestion
The RTT is definitely lower compared to before, thank you for updating packet info.
I tried Advanced and Basic modes, Basic provides better results.
I played with Mudfish on and off for a bit today. Theres still something not correctly working, ping will spike very high or the game doesn't register updates (characters/npcs warp around to 'catch up').
When there is A LOT of action on the screen, it happens frequently.
I had to turn it off because without Mudfish it never happen.
I think routing is still not so good. Thank you for your time but I'll keep trying to see if it improves.
6 year agoDid you try to change a mudfish node based on FAQ - Nodes section for your game item?
cattboy
6 year agoYes. I try Basic and Advanced mode.
I use https://mudfish.net/admin/user/rtt_map to find which node to use, or refresh Item Configuration as below.
I manually set the advanced route or Basic Route
This information is out of date, https://docs.mudfish.net/en/docs/mudfish-cloud-vpn/faq-nodes/#how-to-pick-the-best-mudfish-node-for-game-i-play
I cannot find This information highlighted is not available to me.
WHen I edit an item, it only shows what I posted above
6 year ago@cattboy Oh... I see. If you're looking for the magnifier icon, you can find it at Dashboard menu if your UI mode is 'Simple'.
6 year ago
