yesimacat
10 year ago
Technical Support
There's a problem with MapleStory, when I try to connect to the game, there's a good chance it won't go through character selection and will send me back to the login menu.
Sometimes it does work, but about 10% of the time?
My girlfriend is experiencing the same issue with a different setup, so it's not just me.
I really want to make use of this, the improvement is amazing, but having to try logging in 10 times just to play.. ugh... not worth it. Can you look into it? :(
