Hello! I'm trying to connect with SOCKS5 using SSTap. I'm using ip 46.38.57.43 (moscow tc tel) and port 18081 and I can connect fine, but it only works with TCP. If I use UDP I don't get any internet access. I can connect with UDP, but I can't use the internet.
Why is this? Thanks for your help! :)
Also, how can I connect using the internal ips? I know I have to have mudfish client running, but then?
Thanks again!
8 year ago
