JoXeR
10 year ago
Technical Support
Tested all settings, but overall performance is worse than with WTFast. Probably that is because how bad my ISP is. Changing UDP to TCP in settings improved situation a little bit but delay is too huge anyway.
I wonder if russian Nodes works correctly? I tried to route it that way: RU Europe (Moscow - MediaSoft)[220ms] → DE Europe (Germany - DigitalOcean)[260ms] but in the end it shows, that ping to server with this combination (and any other if using RU nodes) is 1230ms which is even worse than ping to US servers.
