Mudfish Forum
Technical Support
Indy
10 year ago
Technical Support
Hi! I use Mudfish for FFXIV. I just started playing on 2 servers, one on the NA datacenter and one on the JP. I was wondering if there was a way to set up Mudfish so it will work for both without me having to turn it off/on or change config when I swap servers, thanks!
After zooming in, you can drag to move the image.
