For "Dota 2 Item", Europe has not been split into Europe West & Europe East. I am finding it really hard to manually test each node for the lowest ping since i play in Europe West. When I just select Europe as the destination server and select the most efficient path recommended by mudfish, the ping is quite high. Without mudfish my Europe West ping is low. I believe this might have to do with the destination server set by you in mudfish. It would be great if you could add Europe West & Europe East for Dota 2. Thanks!
8 year ago
