Mudfish Forum
Technical Support
9 year ago
Please add Mumbai server (india) for cs go as I am getting high ping while connecting through nearest server ie Singapore.
I dont want to use full vpn mode.
speeddemon1412
9 year agohttp://media.steampowered.com/apps/sdr/network_config.json 뭄바이 밸브 서버는 이렇고 기존에 도쿄 팜과 별개로 이번에 도쿄1(TY2)가 추가되었습니다. "bom": { "desc": "Bombay", "relay_addresses": [ "155.133.233.98:27015-27052", "155.133.233.99:27015-27060" "service_address_ranges": [ "155.133.233.0/24""tyo1": { "desc": "Tokyo (TY2)", "geo": [ 139.68, 35.68 ], "relay_addresses": [ "155.133.245.34:27015-27068", "155.133.245.35:27015-27068" ] },
sambit571
9 year agohow to connect to Mumbai server directly?
sambit571
9 year agoI should be getting ping around 40ms but geting 110ms because of incourecct routing. How to connect to Mumbai server without using sgp server.
loxch
(Forums Admin)
9 year ago> Please add Mumbai server (india) for cs go as I am getting high ping while connecting through nearest server ie Singapore. Please send me some game packets using Packet Capture with Mudfish link while playing the game with Full VPN mode. To add new game server, I need some game packets to analyze. > I dont want to use full vpn mode. Please check Full VPN mode section. > how to connect to Mumbai server directly? I think we should pick a mudfish node manually though I'm not sure that there's a direct connection from your location. It requires more tests.
9 year ago
