Mudfish Forum
Technical Support
9 year ago
Do your servers support udp protocol? I want to connect through another proxy program.
Mudfish VPN supports UDP https://mudfish.net/docs/en/vpn/references/connection_protocols.html
sanya220
9 year agoThis is strange. Because when I try to connect to any server using this instruction https://mudfish.net/docs/en/proxy/socks_proxy.html, through port 18081 using an external proxy program, UDP traffic does not pass at all. Can you help with the setup?
kwangseok
9 year agoPlease confirm are they 18081 at Public IP and 8081 at Private IP. Actually, we can't guarantee working fine that UDP on SOCKS https://mudfish.net/forums/6/topics/39037hello, i try to use mudfish se
hello, i try to use mudfish servers (one example is SG Asia (Singapore - Amazon EC2) 46.137.251.232 ) as SOCKS5 proxy with Proxycap, but why it can connect to some UDP games (i tried Dota 2 and Dauntless) ?? it works fine with TCP games. any help for mudfish to work with Proxycap on UDP games? Thank you very much..
sanya220
9 year agoYes, I used port 18081 on Public IP, and on Private IP it does not work at all.
loxch
(Forums Admin)
8 year agoAre you talking about UDP support via SOCKS v5 protocol? I'm not sure it works properly though I need to check it.
sanya220
8 year agoYes, that’s what I’m talking about. The documentation says that the UDP protocol is supported in SOCKS5.
loxch
(Forums Admin)
8 year agoYes. It's implemented. However I need to check it again whether it works fine. However which program are you using to redirect to SOCKSv5 protocol? If I can know it, I think it's more easier to reproduce your issue.
sanya220
8 year agoI tried to use different programs such as VpnSocks5Client, SocksCaps, Proxifier. Nothing worked
loxch
(Forums Admin)
8 year agoGot it. :-) I'll try to test it again on my side. Thank you for your feedback and let you know when there's a update.
sanya220
8 year agoJust tell me when this will work fine.
kwangseok
8 year agoCould you please check again?
sanya220
8 year agoStill does not work
loxch
(Forums Admin)
8 year agoYep. It shouldn't work because it's patched in the code but not deployed yet. It'll be deployed when next server update happens.
sanya220
8 year agoTell me please when this update will happen.
kwangseok
8 year agoPlease test at PBE * NZ Oceania (Auckland - HDNET) - PBE
sanya220
8 year agoThe same. Still doesnt work
kwangseok
8 year agoI expect NZ Oceania (Auckland - HDNET) - PBE will work for you.
sanya220
8 year agoI checked twice, it still does not work
kwangseok
8 year agoWhat about * MD Europe (Chisinau - MivoCloud) - PBE * ZA South Africa (Johannesburg - Samrand) - PBE
sanya220
8 year agoNone of them work for me.
kwangseok
8 year agoWas it failed to transmission?
sanya220
8 year agoI connected to the server, I can go into the game menu and the lobby without any problems, because the tcp protocol is used there, but as soon as I try to go directly to the game room with the udp protocol, loading does not work anymore.
kwangseok
8 year agoI believe you can connect to ZA South Africa (Johannesburg - Samrand) - PBE as `Public IP address`:`port 18081` with your account so here `169.239.128.66:18081` `sanya220` `your password`
sanya220
8 year agoYes, i did with this settings, but transferring only TCP traffic, not UDP.
sanya220
8 year agoI tried with another program and now looks like it works fine, but only with ZA South Africa (Johannesburg - Samrand) - PBE. What about other servers? Would it work for them too?
kwangseok
8 year agoWe're preparing to deploy a newer version of server program to rest of all Mudfish servers so it's under development. Could you let us know which program did you use and what kind of transferring method at the past failure? Then It'll good to inspect if you send us a packet dump. https://docs.mudfish.net/en/docs/mudfish-cloud-vpn/tech-support-packetdump-wireshark/
sanya220
8 year agoI'm using VpnSocks5Client. I will send a packet dump to your email support@loxch.com
loxch
(Forums Admin)
8 year agoWhen you get a chance, please test it again because now all mudfish nodes are updated with the latest server version.
sanya220
8 year agoNow it works fine. Thank you!
kwangseok
8 year agoCool! :-) I hope now everything goes well with mudfish. Please let me know if there are any other problems.
9 year ago
