Mudfish Forum
Technical Support
9 year ago
I was playing Lost Ark with no Full vpn mode just through The item pay per traffic and after 1 hour of gameplay it used 1Gb of data. I looked at the data usage through my computer said it only used 10mb is there a reason for this.
which node did you use?
Hinukan
9 year agoKR Asia (S. Korea - Sejong Telecom 13)
Hinukan
9 year agoAfter Checking back in another hour of mudfish being closed I lost another 1Gb is there a way to stop this from happening.
Hinukan
9 year agoAny answer Plz i don't want my balance to finish in a couple of days playing at 1 hour a day.
loxch
(Forums Admin)
9 year agoWhen I checked your configuration, it seems you're using Full VPN mode at this moment. Please turn off if you want to avoid it. However please note that even if it's off, you can encounter Amazon EC2, Twitch and Mudfish issue because the game server is at Amazon EC2.
Hinukan
9 year agoOk Thank you i was using I had twitch on when i was using the pay per traffic with lost ark didn't know they where at the same server. Btw is there a way to make sure that my data isn't being used after i turn it off because i do know that is a common issue, cause some time i turn mudfish off then search the web and come back and a couple mb were used when mudfish is off. Btw thank you for refunding 2gb <3.
kwangseok
9 year agoTo make it sure, terminate the Mudfish VPN Launcher completely by the Exit on system tray icon where at next to clock
Hinukan
9 year agoOk thanks i always do that just wanted see if there was another way.Thanks again.
9 year ago
