Mudfish Forum
Technical Support
Coke_Ky
8 year ago
Technical Support
Hi, I have a problem with shutdown the windows after launched the mudfish program. I tried to shutdown without launching mudfish and it works fine, but when I run mudfish and afterward I wanted to shutdown the computer, it stucks at shutdown screen forever and I have to manually press power button to forcefully shut it down. I tried sfc scannow command and it doesn't solve the issue. I'm now using lastest version of the mudfish as I just updated it recently to see if it can solve the issue and yet the problems is still exist. I also checked task manager to see if mudfish.exe, mudflow.exe and mudrun.exe are fully closed and all of them are closed. Please help as I don't wanna shut my computer down by force everytime I used mudfish, thanks in advance.
