jinks787
8 year ago
Technical Support
참 힘드내요... PC성능 윈10 Pro Intel i7-8700 RAM 16G 64bit OS 한번 설치는 되었고, 설정하다가 100%는 떳지만 Full-VPN이 설정되어있는것 같아 초기화 해보니 10%에서 진행이 안되어 언 인스톨을 하여, 다시 인스톨을 하니 애러가 뜨고 더 이상 안됩니다. 사용목적 게임은 로스트 아크입니다. 답변 기다리겠습니다. 감사합니다. 애러네용입니다. ----------------------------------------------------------------------------- Stop MUDFISH Core process. Stop MUDFISH Flow Controller process. Stop MUDFISH Launcher process. Stop Mudfish first Output folder: C:\Program Files (x86)\Mudfish Cloud VPN Extract: mudadm.exe... 100% Extract: muddiag.exe... 100% Extract: mudfish.exe... 100% Extract: mudflow.exe... 100% Extract: mudrun.exe... 100% Extract: mudrun_new.ico... 100% Extract: dbghelp.dll... 100% Created uninstaller: C:\Program Files (x86)\Mudfish Cloud VPN\uninstall.exe Extract: devcon.exe... 100% Extract: tap0901.sys... 100% Extract: tap0901.cat... 100% Extract: OemWin2k.inf... 100% Output folder: C:\Program Files (x86)\Mudfish Cloud VPN devcon.exe hwids returned: 0 Remove old miniport adapter No devices were removed. devcon remove tap0801 returned: 0 Install miniport adapter Device node created. Install is complete when drivers are installed... Updating drivers for tap0901 from C:\Program Files (x86)\Mudfish Cloud VPN\OemWin2k.inf. devcon.exe failed. devcon install returned: 2 devcon cumulative status: 2 Create folder: C:\Users\USER\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Mudfish Cloud VPN Create shortcut: C:\Users\USER\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Mudfish Cloud VPN\Mudfish Launcher.lnk Create shortcut: C:\Users\USER\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Mudfish Cloud VPN\Uninstall Mudfish.lnk Completed -----------------------------------------------------------------------------
