Mudfish Forum
Technical Support
8 year ago
I need help installing mudfish on tp-link archer c7 1750 with openwrt.I cant figure out how to install it
We have an Installation (OpenWrt based routers) instruction for Mudfish Cloud VPN for Router
yayo20
8 year agoIcant figure out how to install mudfish on my router can you walk me through it
kwangseok
8 year agoWhich router is yours with _exact_ name and Version in https://openwrt.org/toh/tp-link/archer-c7-1750?
yayo20
8 year agoThe tp-link Archer c7 1750 is what i have with openwrt version 18.06.1.Its difficult to try and install this
kwangseok
8 year agoI believe you can follow the instruction at https://docs.mudfish.net/en/docs/mudfish-cloud-vpn/router-openwrt-install-mudfish/ if you already have OpenWrt installed TP-Link Archer C7 AC1750 * Connect to your router with SSH client like PuTTY or Git Bash then install some packages as root privilege https://docs.mudfish.net/en/docs/mudfish-cloud-vpn/router-openwrt-install-mudfish/ `opkg update` `opkg install kmod-tun ip zlib libpthread librt libopenssl luci` `opkg install http://mudfish.net/releases/openwrt/packages-18.06/mips_24kc/base/mudfish-pi_2.1.18-1_mips_24kc.ipk` `opkg install http://mudfish.net/releases/openwrt/packages-18.06/mips_24kc/luci/luci-app-mudfish-pi_git-18.285.02627-b9e5d56-1_all.ipk` * Log into Luci web interface then go to `Service → Mudfish` https://docs.mudfish.net/en/docs/mudfish-cloud-vpn/router-openwrt-use-mudfish/ Are there any LTS version of OpenWrt, though? https://openwrt.org/playground/bobafetthotmail/openwrt-lts
yayo20
8 year agoTHANKS MAN GOT IT INSTALLED ON THE ROUTER FINALLY, BUT HOW CAN I TELL IF ITS WORKING WITH MY BATTLEFIELD 5 ON PS4.IVE EQUIPED THE BF5 APP ON THE DASHBOARD AND DOES THIS CHANGE THE IP LIKE WHEN YOU CUT ON FULL VPN OR DOES MY IP STAY THE SAME.
kwangseok
8 year agoMUDEC_00123 , MUDEC_00139 , MUDEC_00145 * Please confirm that How to check the basic functionality works fine in your environment. MUDEC_00062 * Please try to change your Connection ProtocolMUDEC_00086 * Are there any firewalls? MUDEC_00314 * Please try to change your node
yayo20
8 year agoit seems to be wroking im seeing realtime graph shwowing latency lines. but when you select the gaming vpn only not the full vpn does the ip address change when using the gaming vpn or does the ip stay the same because that can tell me if its defiantly working
kwangseok
8 year ago
yayo20
8 year agobattlefield 5 is server based i believe but you guy have it up here to select so guess you guys support it
kwangseok
8 year agoWhat about Full VPN mode?
8 year ago
